Noddy 99
- Aug 14, 2021
- Location
- Telford, Shropshire
- 2009 W211 E-Class E280 Sport Estate (OM642 3-litre diesel V6), 3x remapped, now returned to stock
Hello, chaps,
This comes under "irritation", rather than "problem":
2009 E-Class with 94,000 miles - I'm getting a knocking sound from the steering column when executing low-speed manoeuvres. It happens only when the column moves in the VERTICAL plane, as you work the wheel at low speeds. Just a very slight movement, accompanied by a knock.
Had a quick check from my mechanic. He says there is NO play in the steering itself. He also says that the noise is coming from the steering wheel end, NOT the rack end. He's suggested I put up with it as fixing it will require a full strip-down of the column and steering wheel. However, it's doing my head in and spoiling my full enjoyment of the car.
Any ideas?
Any ideas?
