Knocking Osf Sl320
debidris
Derbyshire
Sl500; Sl320
Anyone got an answer to a problem with 1997 SL320?
1. Have had a slight rattle/knocking noise (actually more of a creak!) from front drivers side which is first heard when I barely touch the brakes, but becomes more noticeable when driving at low speeds over bumps etc., Recently had new front tyres and asked garage to check it out, but nothing reported back although the noise stopped temporarily. Started again about 3 days later. :confused:
Debidris
debidris
debidris
Derbyshire
Sl500; Sl320
excuse my ignorance, but what and where are they?:Oops:
BlackC55
South coast
C43
Anti Roll Bar bushes go on the roll bar at the front suspension
Anti roll bar bushes, these are the bushes that the anti roll bar passes through, one each side, back and front, use a silicon or PTFE spray
debidris
debidris
Derbyshire
Sl500; Sl320
Thanks for this BlackC55 - How easy is it to test if this is the cause ? or do I need to take it into a garage?
BlackC55
South coast
C43
Just look underneath yourself and see if they are no longer snugly fitted to the ARBar.
TV do you have a pic of an ARB so this gentleman can see?
debidris
debidris
Derbyshire
Sl500; Sl320
television - does this mean they need replacing? and since the car has FMBSH should I get it done with MB or any reputable garage? or is it something I could do?
debidris
debidris
Derbyshire
Sl500; Sl320
BlackC55
thanks for the request for photo - although I should let you know, being of the fairer sex, I am no gentleman!
debidris
debidris
Derbyshire
Sl500; Sl320
thank you for this:) - I will try this in the morning - I assume the silicone spray won't be detrimental to the adjacent parts?
Its the safest thing in the world,and it will harm nothing The PTFE one (Screwfix or tool shops) is perfect and leaves no stains and does not dry.
Good luck with it
debidris
debidris
Derbyshire
Sl500; Sl320
Television
Thankyou for all your help - I will have a go first thing - seems like a good way to start a Monday morning!:)
Tel: 020 8863 9233
