knocking sound on A140
gman1958
Hi all, i have a knocking sound, had a look and thourtgh it was one of the track rod ends so changed it, but its still there, have looked at both drop links and other track god and seam all ok, what and were are other bush i need to look at ?
thanks gman.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Try lower wishbone ball joint. It's under tension and so play is generally only noticeable if you attempt to lift it from the bottom of the ball joint.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
check the coil springs they tend to break, also the rear trailing arm bushes fail jack a wheel in the air and see if the wheel move in/out if so new trailing arms required.
jib
G
gman1958
knocking
Thanks for that info guys will have a look.
gman.
