jibcl500
- Oct 22, 2005
- Age
- 56
- Location
- Cambridgeshire
- CL500,ML55,SLK280
All
Recently had a few issues with the CL, recently replaced the air flow meter and also the lamdba sensors. After running diags again after fitting the sensors, same fault 1437 ans 1444 left and right temp sensor cat converters.
Have made contact with Sam and he and I will be chatting at Duxford but would also like some input, the loom for the sensors goes up into the trans tunnel and once the carpets are removed they can be unplugged, removed.
I still need to test the output from the sensor loom, ECP ia also displayed on the dash which is linked to the same problem.
Can I assume the MSG control unit it connected directly to the loom for the lambda sensors or does the loom go via fuses or relays.
many thanks
jib
many thanks
jib
