ourtomtom
- Dec 25, 2011
- Location
- Derby UK
- E200 Kompressor Classic 02 C220 Elegance N
This might appear to be a rambling monologue, so I have itemised the steps to avoid confusion, in determination to sort it myself.
1. Connect battery
2. Switch-on, & usual warning lights illuminate, Fault screen indicates Defective Lamp, Check Lamps.
3. Start Engine, rotate steering wheel lock to lock, all warning lights extinguish.
4. Depress Brake Pedal & BAS, ABS warning lights illuminate, Cruise Control, Speed Limiter & ESP fail to operate, i.e. no longer function.
5. Switch-off engine - fault screen indicates 4 malfunctions. Defective Lamp Check Lamps.
6. Switch-on, start engine, turn on side lights or headlights, depress brake pedal & no warning lights illuminate - everything is working okay
7. Switch-off & the fault screen indicates Defective Lamp, Check Lamps, 1 malfunction.
8. Switch-on & start engine, without depressing brake pedal & all warning lights extinguish,
9. Switch-off, fault screen indicates 1 malfunction.
It boils down to this: on starting engine with battery connected as normal all warning lights extinguish, until you depress the brake pedal and the ABS & BAS warning lights come-on . But with the sidelights or headlights turned-on everything works normally. Switch-off the lights head or side with the brake pedal depressed and the ABS, BAS warning lights illuminate and 4 malfunctions shows on fault screen. Switch-off ignition and switch-on again and fault screen shows only 1 malfunction then shows Defective Lamp, Check Lamps. All the lamps appear to be working perfectly. I have replaced bulbs and the stoplight switch without success. In desperation I tweeted it. See tweet @ourtomtom - i.e.Tom Stack the Author. MB_ Retail responded asking for contact details, which I supplied, but I await their response. I reckon it will be the usual come-on take it to the MB rip-off diag service centre with £££££££ signs racking up as you pull-in. But I will keep you posted. In the meantime if anyone has a suggestion I haven't yet tried please let me know.
Best regards Tom.
1. Connect battery
Best regards Tom.
