Daeths
- Feb 27, 2007
- Location
- North Kent
- T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
Parrot of Doom...or others
GREAT NEWS !
Have identified the fuel leak. It is the first fuel hose going from (fuel out of) the fuel filter towards the common rail. Parrot of Doom. Thankyou very much for your assistance (it is pipe no.29 as shown on your diagram and as suggested as one of the likely culprits)
Couple of press fit releases and away they will come.
One question. do I buy the hose with the fittings on the end or can I simply replace the hose onto the fittings.
I have been told if I just replace the hose I will have hells own job getting it on the black plastic bit that clips into the fuel "thingy" sealed with an o ring (I will definitely be replacing the o rings). They are standard old fashioned push fit with no fixing clips.
Would appreciate your advice, if I can just do the hose then will do tomorrow if not and I need the bits pre-fitted on the ends will be a trip to stealer on Monday.
Thx as always.
Adam
GREAT NEWS !
Thx as always.
Adam
