Leaky rims?
drgaz
Leicestershire
bazzarpixie.co.uk
C320 COUPE
Hi do the rims crack or is it just a case of cleaning the rims on the inside as My 53 C200cdi is always needing the tire pressure adjusting.is it a common fault? regards Gaz
Mic
Oxfordshire
www.bennettgibbons.co.uk
Not an uncommon problem with ''older'' alloy wheels.......in the past my local tyre fitter has had to take a tyre off, scrape and thoroughly clean the rims and reseal with their magic black goo all round the rims where the tyre seats.......refit tyre.....job done.
Mic
Silver_Star
Rural Leicestershire near where Pork Pies and Stil
W203.006, S211.208 Land Rover 90
I wouldn't tyre weld it personally. Lots of places will also turn you away for puncture repairs if your tyres are full of that stuff. Plus it isn't a permanent repair as it will eventually crack.
Just take it to a tyre shop and get them to reseal your rims. They will just need to wire brush where the rim face meets the tyre and then put some sealant on it. - Problem solved.
drgaz
drgaz
Leicestershire
bazzarpixie.co.uk
C320 COUPE
Hi Yes I think I will take it in to the tyre place and have the rims cleaned.
wile I am here,
Any good tyre brands you can recomend I don't do many motorway runs mainly the A44 Leicester to mid wales 300 round trips and seen to be making progress so good grippy tyres.Not botherd about expense.
Mic
Oxfordshire
wile I am here,
Mercedes are majoring on Continentals but in terms of opinions on this Forum you are likely to get a wide range of opinion.
You pays your money and takes your chances provided you are fitting the correct specification tyres.
A lot of helpful information here:
www.tyres-pneus-online.co.uk
Mic
drgaz
drgaz
Leicestershire
bazzarpixie.co.uk
C320 COUPE
Thanks for that I will check out some rubber out I use BRIDGESTONE on my bikes.I like contis to
Just taken my 4 year alloys in for a referb from my V70R,,never kerbed one in all that time but I got do fed up with them loosing pressure, I had the black stuff for a few years and that worked well for quite some time as the others have said
drgaz
drgaz
Leicestershire
bazzarpixie.co.uk
C320 COUPE
I will wip the wheels off the C200 today and drop them off at the tire shop in the morning.I May be tempted to have 4 new tyres wile there off.
