Lemforder drop links not fitting
such
Sunny Essex Coast
W212 Eclass 350 CDI Sport 2012
Got a pair of lemforder droplinks for the front of my W212 from autodoc. The part numbers match the equivalent MB parts.
On fitting, the lemforder parts are longer then the fitted MB parts and I couldn't get them to fit properly.
When they were fitted. they were not perpendicular but at an angle and the screw shafts were at an angle in the mount.
I removed them and looks like a trip to MB parts in the morning is on the cards. I also think I buggered up a boot on one of them so cannot return them.
Part numbers are
36714 01 right​
36713 01 left​
Have I done something incorrect or are these the wrong parts?
MB part numbers are -A2123201189 left
A2123201289 right
Part numbers are
36714 01 right​
36713 01 left​
A2123201289 right
Did you fit them to the wrong sides ?
What do you mean by boot on a drop link ?
such
Sunny Essex Coast
I made sure I had the correct sides.
by the boot i mean the rubber covering the ball joint.
Comparing both parts the lemforder is noticeably longer
Snake Charmer
S211 E320 CDI 2004
Different lengths for Sport? Will the ARB foul anything if you fit them?
malcolm E53 AMG
A comparison price between Lemforder and MB will be interesting I’ve always found genuine drop links from MB reasonably priced
such
Sunny Essex Coast
I paid a total of £37 for both lemforders, vs the online price from MB Newcastle of approx £100.
No doubt I'll be paying more than this tmrw from my local MB.
Snake Charmer
S211 E320 CDI 2004
Can you shorten them or not have the facilities?
such
Sunny Essex Coast
I don't see how other than cutting them, I'll post a picture tmrw of both for comparison.
malcolm E53 AMG
The last pair I bought were for the S210 in 2005 genuine worked out at £25 for the pair how things change
Snake Charmer
S211 E320 CDI 2004
I just looked them up, they look like cast alloy and an odd shape to sleeve easily but not impossible. How much difference on length?
such
Sunny Essex Coast
Not sure but prob at least an inch..
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
brandwooddixon
Wolverhampton
S63 Coupe 2014
Lemforder are a good make, I'd suspect that Autodoc have the wrong ones listed - EuroCarParts sold me brake pads that were the wrong size. Turns out that I have Sport discs which are larger and therefore require larger pads, but they had none in stock and the ones sold to me were the standard fit.
I suspect that something similar is going on here.
horatio
Herts
190E, CLK
I have found sport being a few mm difference to standard/elegance on drop links before but an inch is probably for a completely different car!
I only use autodoc when I can’t find what I need elsewhere or the price difference is huge tbh.
such
Sunny Essex Coast
  • #17
Part numbers are
36714 01 right​
36713 01 left​
A2123201289 right
The part numbers of the MB links removed are A204 3201789 and A2043201889 which is different to what is listed here:
malcolm E53 AMG
What’s the mileage on your car I think my front drop links are starting to complain at 80k miles with a slight knock on full lock?
