Life expectancy of ribbed auxiliary drive belt
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
Hi All
What is the typical life expectancy of the multi-ribbed, auxiliary drive belt, the one that drives the alternator, coolant pump, power steering pump, etc?
Mine is showing its age and has developed slight cracking but my indie is not unduly worried. He'll change it the next time my car is in for servicing which should be in 2 - 3 months time.
Is it expensive and difficult to replace? Looks a simple and quick enough task.
REGARDS
Phil
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
no idea of the life expectancy, but when i got my viscous fan coupling replaced my indie also replaced the belt and showed me the old one, it had as you say lots of cracks etc so I didn't mind.
Better to have a nice new one than have it go snap on you when you least expect it.
cheers
\anyweb
hmang
ask your indie if he'll come out at mid night and change it at the side of the road,in the rain ...for free...and then see how unduly worried he is.
BlackC55
South coast
C43
I have seen them snap and cause some damage. As soon as the cracks appear get it changed. It not exactly difficult or expensive to do either.
Cnics
Worksop - UK
www.cnics.co.uk
and for the price, put a new one on whenever you take it off for anything else... ie viscous fan like anyweb says.
All i know is mine did 95k before i had a viscous fan and alternator pulley done, i was therefore more than happy to put a new belt on.
Rob
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I replaced mine on the CL took 10 mins if that, bought it from eurosendthewrongparts, less than £20, made by Continental, if the rubber starts to look fractured, cracks etc then replace it. If it breaks the only dramatic problem is loss of power steering and the possibly overheating if driven any great distance.
The will be a diagram in the owners manual for the belt so once removed its easy to forget where it went.
jib
Sprint'n'Go
Ashton-under-Lyne, Near Manchester
I have just bought a 2000X 4ltr jeep cherokee and as part of my service regime I changed the belt. It was genuine so could have been original and was still doing it's job but was starting to look a bit pathetic after 113k. The new one from Jeep came with the familiar Milton Keynes despatch sticker on the packet so I asked at the parts desk guy and he confirmed all the parts come from the shared daimler chrysler warehouse. Annoyingly, when I had changed it I compared it to one a Merc mechanic gave me after some warranty work on the van. It was as new and appeares to be dimensionaly identical to the jeep one. This is a suprise as one is for an I6 american built petrol engine and the other is for a german built I5 diesel. I wonder who is cheapest and if their are any other shared service parts?
dava
The Toon
Cant go along with your indies thoughts, if it does snap and they do! It will only mean you got no power steering, just what you need on a bend and they do cause quite a bit of damage if they get tangled up.
mike65
Ireland
www.futuremusiccorp.net
If its got lots of those little cross-ways cracks and any signs of glazing then replace it. Cheap and as said a 10 min job if you know how to loosen/tighten the belt adjuster contraption.
Mike.
hmang
i've heard of this twice and seen it once on 210 e320 cdi where the belt snaps and puts a hole in the radiator.
total misery...if in doubt change it.
rodisi
Germany
E220CDI 1999 W210
I'm just about to order and change my belt so I'm reviving this thread because I can't figure out where the tensioner is, if there is one or if I need to loosen a part like the alternator. I'd appreciate a hint. The car is an E220 (W210 - whatever that means) and has air conditioning. If I'm also correct, the part number is A0149970492 or A0129970792.
Frontstep
T210 320cdi
Use a mirror and a light and this sort of thing appears you just use a spanner a 17mm on the torq head if I remember then just rotate against the spring pressure.
A picture of the belt route is useful.
Its just below the power steering pump pulley in your picture.
turbopete
Spennymoor
i think i better invest in a new belt before too long then. its the original belt (unless it was changed in its first 7k miles) so almost 12 years and 115k miles old!
PieterH
Pretoria, South Africa
W203 CDI 220
Hi, the belt (known as the serpentine belt on my CDI 220 was badly worn by 148 000 km. I paid 44 pounds for a new one at MB. (I stay in South Africa so the cost in Rands was R575.00) I took me 15 minutes to replace.
drdel
Beds
2011 e class 350 cdi est
No brainer- the actual answer doesn't matter. You've obviously asked the question because you have a concern. You're in doubt so change it; sleep peacefully and drive relaxed !!
By looking at the belt where it passes over the smallest pulley, if it is time up for the belt crazing will be seen on the belt over the smallest pulley
