light fault..
initialbdriftracer
Northern Ireland
www.facebook.com
W220 s500. Year 2000 airmatic
kept meaning to bring this up , so ...
when i turn on the sidelights , the bulb failure warning comes on..
all the lights work perfect.. but one of the tiny bulbs in the heater control panel is not working.... could this be the cause...
whitenemesis
CLS55 AMG '05
No, won't be an interior light.
Have you checked the brake lights?
star
Reading
Smart + others :)
Have you the correct wattage of rear side bulbs and don't forget number plate lamps.
Steve@Avantgarde
Bristol/Somerset
A tip about light warnings on Mercs.
The warning light will come on only when it sees the bulb not working, not as soon as the ignition is on, so turn the lights on in sequence slowly and see what immuminates the warning light.
For example:
Side lights, dipped beam, main beam, fog lamps front, fog lamps rear, reverse, then brakes.
When you see the warning light come on you can know straight away what circuit to look at.
mersum1es
Finland
BAZZER1
FERNDOWN DORSET
E320cdi AVANTGARDE SELECT
I had the same fault, see my Thread 11/10/12 and a lot of good advice given by Members, I eventually knuckled it down after checking and rechecking all Light Bulbs to a Rear Brake Light Filament which was intermittently making and breaking contact, not an easy fault to find even with a meter, so check and replace your Brake Light Bulbs with good quality ones, I replaced mine with Osram Bulbs, result, fault cleared.
Best regards
BAZZER1
BAZZER1
FERNDOWN DORSET
Forgot to mention, make sure that all of the Bulb Holder Contacts are clean and free from corrosion before fitting the new bulbs
BAZZER1
initialbdriftracer
initialbdriftracer
Northern Ireland
www.facebook.com
all brake light bulbs are new..
it seems to come on as soon as the heater control panel lights up.... well, half of it...
i already had a go at stripping one down.. not a job i want to do on my own car...
i been putting up with it for a year now.. so im kinda used to it, but would be nice to have it fixed too.. cheers for the advice..
much appreciated..
wireman
lancashire
My guess
One or more of the parking light or number plate lamps is tired or has dirty contacts.
