thats a pity,the one on my daughters 1974 corsa is.
202 C class does NOT have illuminated light switch, regardless of what year it is.
There is a bulb in the switch, the rear fog warning light bulb, it's in the centre spindle, pull off the handle and you will see it.I will have to disagree with you here, my friends was definitly 100% illuminated the Haynes manual also refers to changing the bulb in the switch (but as so often is the case with Haynes its c**p).
Its not a problem but if its supposed to be illuminated i,d rather it work than not.
Yes i know about that one it illuminates when the rear fog lights are on.
My mates had another "switch" illumination bulb.
Warning lamps must be provided where fog lamps are fitted as they are illegal when there is no fog and they are turned on in some countries.
Malcolm
I thought this was the case, but the 202 has no lamp indication for the front fogs only when you pull the switch again and put the rear one on do you get the lamp on.
