Limp mode - code P14B700
such
Sunny Essex Coast
W212 Eclass 350 CDI Sport 2012
Had the W212 go into limp mode a couple of times recently with no warning lights/messages. Restarted just fine.
Scanned using CarlyMB with the code P14B700 which suggests a stuck EGR valve.
Are these easy to remove and clean or better to replace? Is there anything else to be done alongside this?
oscarham
Gloucestershire
1990 W126 300SE - 50 shades of blue
Hey,
It's often possible to clean the EGR valve, depending on your circumstances and cost of the part it may be easier to just replace it but that's up to you.
Sorry i can't be much help.
such
Sunny Essex Coast
Hey,
Thanks, I replaced it with an aftermarket - Lucas brand which did not work as expected so currently have the original MB EGR back in place. I didn't clean it as it was not as bad as I expected and I bought the new one. In hindsight I should have cleaned it whilst it was off! Car is going into MB specialist tmrw to be sorted hopefully.
oscarham
Gloucestershire
I'm sure the specialist will sort it - best of luck mate
