2009 C-Class with command and linguatronic.
I would be grateful if anyone could confirm how the command "Dial Name" should work on this vehicle. Page 15 of the linguatronic book says that you can use the command "Dial Name" and then say the name and the system will dial the number, but this does not work with my car.
When using the command "Dial Name" I get the response "please select a line number" I then have to look at the screen and select which entry to dial.
The Dealer agreed this is wrong, but Mercedes UK have informed the dealer that this is how it is designed to work.
Thanks in advance.
Thanks in advance.
