Live feed from battery into cab Citan 2018
Karl Hobson
Citan cdi 111 sport 2018
Hi I have an 18 plate Mercedes Citan cdi111sport and need a permanent live feed direct from the battery into the cab but cant find any grommets through, any help locating where access through would be appreciated Thank You
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Follow the wiring loom from your engine bay fusebox?
Is there not a SAM inside the vehicle with a feed on the side of it?
Tony Dyson
God's Country
As the Citan is a rebadged Renault Kangoo you may find more support on the Renault forums?
K
Karl Hobson
Only just got home from work ..... Mercs generally have what Merc call a SAM .... Signal Acquisition Module basically a fuse/relay box
Thanks for reply, I'm currently running from the rear of the accessorie socket as this is rated at 10amp max but switches off with the ignition and this is not ideal as the radio I have installed needs to be then manually powered up once its lost power so ideally I would like to run a cable direct from the van battery to the two way radio in the cab that does draw around the 10 amp mark when it is transmitting....
