Flying Scot
- Mar 24, 2006
- Location
- MOZZERWELL North Lanarkshire
- SL 500 R129 1995
Suckmyrockets said:Thanks philharve & Flying Scot
Take my hands off of the wheel?
Did I not mention the inconvenience of steering correction whilst using the phone, reading a map and lighting a cigarette (all at the same time) - and as for driving with your knees...
I am attempting to not be overly critical - my 'other car' is a 1995 Mitsubishi Evo III and therefore at completely the other end of the steering vagueness spectrum i.e. there isn't any
However, I did attempt a 'slight release of grip' (Flying Scot) on the wheel in the interest of seeing whether it was an abvious issue with tracking - the car did not attempt to veer off course; further investigation revealed that the veicle was responding to track condition (well, M4 surface around Bristol) - this became even more noticeable traversing some favourite B-roads where I was concentrating like mad to keep the car between the verges at some rather modest speeds...not the most pleasant nor enjoyable sensation and as I mentioned previously, not what I expected from a M-B.
However, I feel my expectations are realistic - if I wanted to be frightened, I'd blindfold myself and then try the motorway trip, but in the wrong direction and on the opposite carriageway...!!
I was just wondering if anyone has approached M-B UK with these concerns?
There may be a perfectly reasonable explanation that collectively hasn't been found by forum members but is known to M-B e.g. worn track rod ends - do we know if the car has a propencity for 'munching' any particular parts...
Just a thought...
Julian
cant really decide what to make of this post is it serious tongue in cheek or just flippant and after reading the post on the 'other place' i can only suggest that crosswind stability on the Severn bridge is down to lots of things including the cars aerodynamic profile sheesh even your F1 car is seriously affected by wind conditions - However i thought this thread was about the cars basic straight line instability or more correctly its inherent lack of any. That said If you drive a M Evo III i wonder if you are not expecting a lot (too much) from your MB I regularly drive a MK2 Toyota MR2 a Lancia Delta Integralle and a Volvo 850 Est and a Fiat Punto as well as the SL500 they all respond quite differently for obvious reasons. I dont expect the SL to corner like the MR2 or the Integralle and i know i can relax when in the SL and let the car follow the road with minimum input from me - in the Integralle or the MR2 if i sneeze i will be off the road
just a thought or two
