Location of the Module box (k40) on Merc CLK
minster47
I am looking to locate the position of the Module Box (k40) to check the fuses/relay - can someone please confirm where it is on my CLK 230k (Year2000)
Not quite that simple.
You have k40/2 on the drivers side and K40/4 in the passenger side fuse box
M
minster47
Malcolm, Many thanks for the prompt reply - are both k/40's located under the bonnet? If so, do you where I should be looking as the only thing I can find are the 3 fuse boxes located (1) O/S under bonnet (2) O/S inside car door (3) in the boot near battery.
Thanks Colin
Take a look at your other post
