Ok thank you, is there anything I need to look out for when buying? I’ve done some research, the roof cables are hydraulic and can split? I’m looking at the diesel are there common problems with EGR or DPF?Hello and welcome,
Buy a V6 or V8 petrol, all Mercedes are heavy and smaller engines don’t always give the increased economy you’d expect.
HiHi and welcome
Roof cables can be an issue as well as the air cap not going back in.Ok thank you, is there anything I need to look out for when buying? I’ve done some research, the roof cables are hydraulic and can split? I’m looking at the diesel are there common problems with EGR or DPF?
Thank you
