Loosing water
Status
Not open for further replies.
230TErry
Belfast
1955 220a, 1998 E430 Estate, 1972 280se 3.5, 2001 E320CDI Estate
Hope i am not repeating myself but the topic I posted has disappeared of the list!
My 1990 230TE is leaking coolant into the passenger compartment. Both front and rear and both side footwells are full of water and I am loosing coolant at about 1 litre a day!
Has the matrix gone or has anyone had a similar problem and found a simple solution. I assume the dash needs to come out to get at the heater matrix. I have checked all the hoses I can find and been unable to locate any leaks.
Help please.
JR
london
HAVE HAD A VERY SIMILAR PROBLEM AND IT WAS THE HEATER MATRIX, GOOD NEWS WAS THAT EURO-PARTS STOCK AN OE REPLACEMENT FOR A LOT LESS THAN THE MERC DEALER WANTED, BAD NEWS IS A LOT OF THE DASH / CENTRE CONSOL HAD TO COME OUT TO FIT THE NEW ONE.
HOPE THIS HELPS
ianallen2
leicester
sounds very much like the matrix to me . Having all that water in the footwells says it only comes from the matrix unless you wash the car with all windows open . :?
230TErry
Belfast
Thanks for that JR. How long did it take to replace? I assume I can put a hose across the flow and return in the engine bay to cut out the matrix to confirm that this is the source of the leak though it's ****** cold at the minute to have no heat :(
230TErry
Belfast
Status
