Low oil level
petenaylor
Shropshire
2001 CLK230K Convertible in silver
Hi all
Driving to work this morning my 1997 w210 e class pop up a 'oil level at minimum' warning light. Does anyone recommend a certain type of oil? Also how much should I put in?
Many thanks
Pete.
Hi all
Many thanks
Pete.
Just incase it is an erroneous message, see what happens on the way home.
Malcolm
G
gchild
i would check the level at the dipstick first. the oil sensor may not me accurate.
P
petenaylor
Shropshire
Will do, thanks guys.
It will probably require a top up, check the oil using the manual method (dipstick) then top up as required. I would top up with the same make and type of oil as you are using. De[pending upon who did the last service it should be stamped in the service booklet.
One benefit from topping the oil up in a 210 is that the ASSYST service counter adds some miles until the next service :cool:
P
petenaylor
Shropshire
Will do, if I do need to top up how much should i put in? The oil comes in 1 litre or 4.5 litre bottles.
ba9rn
From the Low to High mark on the dipstick, it should be around 2 litres. Obviously, if it is below the low mark you'll need to add more than that.
mioba
Nottingham and Köln
usually 1 litler is difference between max and min mark.
i think its always useful to have a gallon of oil in the garage for topping purposes.
P
petenaylor
Shropshire
Great, thanks for your help.
malcolm E53 AMG
Just a word of warning.
Don't overfill the engine with oil. This is very easily done as the level should be checked hot. I would advise you not to put any more than half a litre in at a time as the engine overfill warning will keep coming up on the dash at the slightest overfill.
This can be very irritating and its not easy to remove excess oil.
www.W140.co.uk&www.r129.co
