jberks
- May 12, 2004
- Jaguar XF 3.0 S, LR Freelander 2, Fiat 500 & Fiat Panda
Hi all,
mentioned this before. 2003 E220cdi (211). Wouldn't start one morning so we replaced the battery. Later found out that the battery we replaced was only 2 years old and probably fine.
Since then, every few days we get a consumers off message. Left longer, it does start turning things off. Parktronic didn't work this morning though the radio was fine (odd?).
I suspect, left long enough and she wouldn't start. After a run she's fine. after a charge up she's fine.
We've had an auto electrician spend over an hour on it and he can't find a problem. Current draw is nominal, charging rate is fine.
Is there anything that can suddenly wake up after being parked for a while?
Any ideas gratefully accepted....
