LT on 1994 c200 coils
1340paul
hello
can anyone tell me, on the LT side of the coils does it matter which way round the wires go, the only markings i can find are on the plastic cover that clips over the 2 wires which have the numbers 1 and 15 also on the cover are the letters PBT in inverted brackets, as you look at the cover this is to the top right.
the wires are pink with white these seem to be a live feed to both coils from a fuse,
then a black with white to one coil
and black to the other coil,
i presume these are the signal from the ecu.
many thanks paul
1340paul
  • #2
good news car up and running.
sorted the LT wires if anyone else has the same problem,
15 is the red and pink live feed to both coils
1 is black wire to one coil, black and white to the other coil
also noticed on the ecu is the letters PBT, which is also on the coil wire cover so pbt is black and black and white from ecu to coils.
hope this helps someone else
cheers paul
Sorry you did not get an answer on this Paul, but at least you are up and running again. thanks for the info if someone ask in the future
Tel: 020 8863 9233
