My c180 kompressor has developed a lumpy idle, the agent says I have done too many low revs short journies and this has caused the valves on number three cylinder to become sticky and gummy. His solution is to fit a new cylinder head - ouch this sounds a little extreme. I have tried running the car for a good distance in 3rd gear to try to burn off any residues but on returning home the car idled normally for 5 seconds then faultered and stuttered and the engine symbol displayed on the drivers panel came on again. It seems that the warning symbol on the dash resets itself every so often and idle is normal, then it suddenly goes lumpy again and the warning light comes on again. I would have thought that if the problem is with the valves the symptoms would have been consistant rather than intermitant. Any ideas before I part with big money?
