Wondering if anyone has any experience with a poor idle. Not a misfire but more of what appears to be an idle leak.
I’ve tried both of the EGR switch over valves that are quick and easy to swap to no avail.
I’ve not tried the EGR value itself on the rear of the engine.
No fault codes at all. Not sure what to look for with live values. Seems to go bad idle after the secondary air pump turns on and it doesn’t always occur right away.
Doesn’t appear to be a misfire or coil pack.
There was a split hose from the bottom of the manifold so used a pipe repair kit and think it’s ok.
MAF bracket was previously broken so letting in unmetered air but now resolved.
Any other ideas? Car is of low value so am loathe to spend lots of diagnosis.
Can’t see any other split / disconnected hoses. Would be good to get to connected to something that could detect a leak like a smoke machine of sorts?
