Fast_Lane_Dane
- Mar 31, 2006
- Location
- Denmark
- W126 300SE 1986, M103 180 hp cat.
Hi, I'm the happy owner of a w126 380 SE from -82 which has done 140 k miles. the V8 M116 engine has a knocking/tapping noise at cold start, which disappears after the first 2 miles or so. I have changed 4 of the 8 hydraulic valve lifters on the left bank of the V, where the noise is coming from, but the noise is still there. Apart from the tapping noise, oil pressure, temperature, idle/revving and all is OK. I've heard from another 380SE owner with the similiar problem that he've changed valve lifters, cam shafts, valve shims and all without getting rid of the noise, and that he had been told that it could be due to a blocked oil channel (don't know if that's the correct tech term). Have any of you out there heard about the oil channel issue before?
Thanks, Hans
Thanks, Hans
