I've recently purchased a 1988 560 SEC to use as a donor for its engine.
The engine will be going in my 1985 500 SEL, which currently has the older 117.963 engine.
I'll be using the inlet/injection system off my original engine to remove the need for changing the KE jet computer from the SEC.
I was reading into the EZL system, and I know my old style distributor will fit the 5.6 engine, but I like the sound of the benefits of the newer EZL, since I run LPG, and spark quality is important.
A couple of things really, The EZL needs a couple of sensors adding to my old intake system to make it work. Coolant temp sensor, and throttle position switch.
I already have both of these, but for running the old type idle stabilisation computer, which i'm going to keep.
I'm away from where my car is at the moment, so can't check first hand, but Is there a position on the manifold to accept the second temperature sensor?
Also, i'm going to need to install a throttle switch to sense idle for the idle computer, and WOT for the EZL. Here's the tricky one... I could probably use the combination switch from the original 5.6 throttle body, but the idle computer needs a 12v input for idle, and the EZL uses a grounded input for WOT. Would it matter if the EZL saw 12v at its input, and the idle computer was grounded at its input? If not I could tie the inputs together and feed either side of the switch to ground and 12v respectively.
I've got a feeling that i'm just going to have to bite the bullet and use my old style distributor.
