Hello every all !!
I'm new about this forum, I write to have any suggest about a 722.4 automatic transmission rebuild.
Before rebuilt we have slipping in 4 clutch and problem with reverse. I completely rebuilt transmission and I found broken plate of rear clutch and a sealing of the main shaft broken, I replaced all the frictions, seal, gaskets and bands.
Now I have no second- third- fourth clutch. Only first and reverse. My colleague changed all the tubes for depressure , maybe some tube are in the incorrect position? Can the vacuum valve bring no shift? Or the accelerator control ? Thank you in advance !!
