stumo
- Sep 4, 2008
- Location
- VIC, Australia
- ML270CDI x3 2002,03,04 | Sprinter 316CDI 2003 LWB
- Thread Starter
- Thread starter
- #21
Oh I see you took the EGR plumbing out, maybe thats what made removal easier? Usually you have to remove the rail because the EGR plumbing doesn't allow clearance for the manifold to come out.
By "heat exchanger" do you mean the EGR cooler, or the oil cooler behind the oil filter housing? That exchanges heat between coolant and engine oil and ATF. Why do you want to remove it? They usually don't give any trouble have you had cooling issues?
My advice would be to do the EGR delete first, and then run it to make sure there are no codes with a real MAF sensor. Then do the MAF delete once you know for sure the EGR delete is working properly. Note that you may need to use a higher resistance value for the MAF delete, the last one I did needed an 8k2 resistor rather than 5k6. You need about 2.2V on MAF pin 5 when the EGR is off and 1.5V when EGR is on.
