MAF Wire/Harness Chaffing. Where to look?
Brian23
EClass
Hi I have an engine light on and the fault code says the Hot film MAF Sensor short circuit to earth. So is this the MAF that needs changing or the wiring harness chaffing? I have looked at the harness, but nothing is obvious. Is there a certain place where this is known to happen?
2005 E200 W211
mattkh
England
A160 W168 1999 1.6
How many coloured wires can you see going to the MAF sensor ?
Oldspanners
Normandy
C CLASS 2004 C180
2005 E200 W211
Unplug the MAF and see if the fault changes.
Flyinspanner
Ruislip
No, but the fault code (if cleared) may then change to ‘open circuit’. Which would point to the sensor being at fault.
B
Brian23
EClass
B
Brian23
EClass
Thank you. I will do that.
B
Brian23
EClass
Ok cleared the faults. The light has gone out. Started the car, the light is still out. Checked again for faults, non. Disconected the MAF ran the car, the light is still off, but on checking faults I have P200A-B2/5 (Hot Film MAF) short circuit to ground/open Circuit in wiring (P0102)
I think this one was there before. The thing is that this is an intermittant fault and now it is cleared may not reappear for days or weeks, but with my MoT next week I didn't want it coming on before then and I also need to fix this.
You need to clear the fault after you unplug the MAF and see if it comes back.
B
Brian23
EClass
Ok unplugged MAF, Cleared faults. Started car. Checked faults. P200A-B2/5 (Hot Film MAF) short circuit to ground/open Circuit in wiring (P0102). Cleared fault connected MAF, started the car, checked faults. No faults, but as I said this is an intermittant fault and now that it is cleared may not reappear for days or weeks.
Kev555
N.I
ive found Short circuit to earth message in my case has been a faulty sensor. Intermittent would lead me to think MAF faulty, but dont take my word for it LOL
B
Brian23
EClass
I have just bought a new breather pipe as it is recommended that you change this when changing the MAF. I have noticed that the old pipe is very slack and soft. Could this be also causing a problem with the MAF?
B
Brian23
EClass
Thank you
B
Brian23
EClass
I have now changed the MAF. It was not as difficult as I thought, I've cleared the faults and now hope for the best. One thing that is strange, is that the new MAF had a tiny Resistor? between the two pegs in the photo. The photo is of the old one that doesn't have this.
