older Merc guy
- Mar 30, 2024
- Petrol 1996cc September 1992
Will the electro magnetic radiator cooling fan still function with cracks in it?
Thank you. I'm having great trouble sourcing a new one. Very limited suppliers and not getting any feedback from themYes but in reality will likely need replacing sooner rather than later due to the speed in which it runs, it could let go and damage other parts when it does
Try DronsfieldsThank you. I'm having great trouble sourcing a new one. Very limited suppliers and not getting any feedback from them
Okay. From what I can gather, the electromagnetic clutch should cut in at about 102 Centigrade. On a UK spec. car without air conditioning, the fan has no relay, the positive being supplied from fuse 10 (?) through the temperature sender to the clutch solenoid. The solenoid is permanently earthed.No air con. Not a viscous fan but a magneto fan. Only one fan works off the auxiliary belt and supposed to ' lock on ' once it reaches 102c.thankyou.
Is there video to show how to apply directly? PleaseWhat car is it the you have? Please post up the first 6 letters/digits of the VIN e.g. WDD210, which indicates a W210.
Have you checked that the fan is actually working e.g. applying 12V to it directly?
Some cars have an additional fan control unit that can fail.
WDB2010242G009682. Thank you very muchPost full VIN please, and I will tell you clutch part number
