Maintenance costs! - and I thought the service was expensive
Status
Not open for further replies.
Shude
Manchester, UK
www.c230k.co.uk
Just got my estimate-by-post from the stealership.  This was to repair the things noted on the end of my B service that needed some attention.
This is what they're going to do:
  • Replace V belt
  • Replace stabiliser link
  • Rinse oil cooler and fluid lines
  • Replace fluid hose for auto tranny
  • Remove aircon compressor / install new
  • Test and install all air conditioners
  • Extract refrigerant, check for leaks and refill
  • Replace brake light switch
That's 7.9 hours so £513.50 +VAT
Here are the parts they need:
  • V Belt
  • Belt
  • Rod
  • Leitung (x2)
  • Coller Hose
  • Hose
  • Line (x2)
  • Seal oil drain
  • Seal ring
  • Compressor (that's the daddy of the parts list)
  • Stoplight switch
  • Oil spec Auto
Parts come to £738.12 +VAT
£1251.62+VAT total (£1470.65)
Does that seem expensive to anyone else?  Anyone got any money they can lend me? :(  Bit of a mountain after the £587 service last month :(
Obviously I need to get these things done, can anyone tell me which part of those processes cost the most and the least, so I can break it up a bit and get them fixed over a period of time?
(Edited by Shude at 8:52 am on May 24, 2002)
dave elcome
Maidstone kent
Maintenance costs!
Give Andy a ring, he's even closer to you.
David S
London
Maintenance costs!
I know a very good air con specialist is Perivale (just off A40), London.
I imagine the compressor s/f must be the most expensive component of your estimate. Give them a ring and ask for an estimate.
www.car-aircon.co.uk
Regards
David
Koolvin
www.mbclub.co.uk
Maintenance costs!
Regards
David
I know them too! they r0ck!!!!
Shude
Manchester, UK
www.c230k.co.uk
Maintenance costs!
the compressor is 627.70 including VAT from the stealership.
I wonder if I can get a reconditioned one, or if the current one can be repaired, it is apparently "leaking".  The system was recharged a year ago and it's still working dispite the leak and I don't know how long it will last before it fails.  Aircon compressors are always expensive anyway, regardless of make or model of car, they cost about £500 on a vauxhall.
Shude
Manchester, UK
www.c230k.co.uk
Maintenance costs!
I have found an independent place about 5 minutes from my house, literally.  They seem to specialise in refridgerated trucks but they do passenger cars as well.  I will call them today to find out what I have to do.
http://www.airconco.net/vehicle/
Shude
Manchester, UK
www.c230k.co.uk
Maintenance costs!
About 5 minutes after I mailed them I got this reply:
___________________________
Nick, I would like to check the system myself before advising you, if you
could bring it in I will test the system and give you an honest estimate,
you may find that there is nothing wrong with it. If you give us a call on
01706 361966 we will book you in.
Regards
Justin
I might just do that :biggrin:
steveperry
South Wales (UK)
www.mercedes-benz.co.uk
2010 CLS350CDI Gr.Ed.
Maintenance costs!
Shude/Nick,
Those stealership prices don't suprise me at all,
sounds like you have the a/c side of things under
control, why not give Andy a bell for the rest of
the work? Heh or you could take Vin up on his idea
and drive to George.
S.
Stewart Smith
Hartlepool
Maintenance costs!
I reckon the only reason to use a stealership is to get the book stamped - then go to a specialist to get the work done.
7.9 hours = £500 ???? Eeek!!!
The headgasket,diff and arm on mine come to about 15 hours in total. (  Still awaiting the signature warranty permission to carry out the work ).
I reckon a day on the driveway replacing all the brake disks and pads at a europarts total cost of £160 is the plan for the weekend then, not a dealership trip at those labour charges.
fuzzer
Scotland
W202
Maintenance costs!
Thats the best part of  £1500 towards a new car if you think about it another way.
Andy
West Midlands
www.mercedesservicing.com
Maintenance costs!
Hi Shude
Email me with chassis number direct from my website & I will check what prices I can come up with on the compressor. I must admit its usually the condensor that gives us the most leaks. But a compressor can go wrong. I am assuming they have used an UV dye. If so we can have a look without recharging the system.
Regards
Andy @ www.mercedesservicing.com
Status
