drone
- Jun 14, 2021
- 350 slk, 200kW, 220CDI estate.
My old 220 cdi has the oil level readout on the dash, at times I find this a right PITA.
I guess a lot of other folks do also as I've seen several forums agonising about it, so I decided to buy one. Not cheap but I noticed that the part number for the dipstick for the 220 cdi is the same as the part number for the 350 slk which I also own t'was the work of a moment to gather up a 2 foot steel rule and measure the distance from the stop at the top to the max and minimum levels, 510mm and 535mm respectively on my clk dipstick.
I had recently bought a dipstick from e-bay for the transmission oil level and a quick felt pen mark at the appropriate place and a piece of 10mm inside diameter clear pvc tube that I had laying around was quickly cut to length and slid easily over the dipstick and bob's your uncle. The image is self explanatory.
My display says the oil level is ok, the dipstick says it's about 1/4 the way up from the lower mark. I used the 20 centigrade mark as the minimum level btw.
The pvc tube stops the dipstick from entering too far, I'm feeling rather smug.
And the proof of the Pudding!
