- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
I now have all the info that you need
Theres no need to dismantle the roof to straighten the bottom- if that's what the problem is.
If the seal isn't damaged then just remove the seal around the bottom of the pillar, straighten the bent bit and refit the seal.
If the seal is damaged then replacement is a bit more involved but principle is the same- remove seal, straighten bent bit and refit seal
Top service as always
I have an interesting question regarding water ingress into my r230 SL (2002)
I have fettled around the boot of my car for 2 wet winters now and the water stopped for a few months and then came back. However - I am loading towels and absorbent tissue onto the sides of inside boot under c pillars and now see that the top of towels stays bone dry whilst the bottom of them get soaked. It's like it's trickling down the carpet and runs underneath the towels and down into the boot.
I refuse to sell and / or give up.
I WiLL fix it !!!!!
I WiLL fix it !!!!!
