Chuck.Blue25
- Jun 10, 2023
- 2006 C230 Sport
I find myself in a position where I have to try and fix a problem likely caused by my nephew and stepfather attempting to jumpstart my deceased mother's C230 with the cables reversed while I was out of town for a month. Car ran PERFECTLY prior to me leaving other than having an ESP fault on the dash. Both parties involved admitted to their mistake and simply gave up after they failed. I came home to find the car sitting with the doors unlocked, the airbox cover off, the wipers up (though the switch was off) and the battery completely drained. The second I put my charger on the battery the alarm started blaring, the windshield wipers started going, and the washer motor started spraying continuously and the lights came on. Key was NOT in the ignition. I disconnected the horns and played with the stalk trying to get the wipers off and the washer to stop; no luck. I DID get the car to fire off; it runs fine. That stopped the wipers, but not the washer motor. I cycled the car on and off and it successfully cranks, but the washer motor would not stop. Ultimately, I turned the car off and put the battery on my charger. The tail lights would NOT turn off no matter what position I put the headlight knob on. I decided to disconnect the battery and try again the next day .
Well, here I am today and here's what I am currently dealing with:
-reconnected battery and tail lights, with center brake light bar illuminated come on and stay on as do headlights.
-no highbeam/lowbeam function
-no washer motor running this time
-no "wipers gone wild"
-blinkers do not work
-wipers work
-wiper wash motor works
-instrument cluster reads "Display malfunction, visit workshop" and "battery alternator, visit workshop" and "Speedtronic, drive to workshop"
-check engine light is on
-radio works fine
-AC works fine
-windows go up and down fine
-central door locks work fine.
-remote trunk release does not work
Now here's my main problem that I hope someone can help me with: I cannot find a relay or a fuse to pull in order to disable the tail/brakelights so that I can let the car sit without disconnecting the battery and having it fully discharge again. I've checked all three fuse box schematics and can't find what I need. I reasonably certain that these idiots fried the front SAM when they jumped the car backwards, but that's only speculation at this point. My stepfather has dementia and we are only keeping this car as a "worst case scenario" option for him if he can't get ahold of anyone else in an emergency. I at least need this car to car to crank and run without having to first reconnect the battery. I can't do that if I can't get the lights to stay off.
Thanks in advance. It would REALLY help me if you could just respond via my e-mail: chuck.blue25@gmail.com
Chuck Blue
Opelika, AL
2006 C230 Sport
-wipers work
-radio works fine
-AC works fine
Chuck Blue
Opelika, AL
2006 C230 Sport
