AdamSnuggs
- Apr 8, 2024
- E350 Bluetec 2016 saloon diesel
Hello everyone, I am new to this forum and I am hoping I will be able to help as well as be helped with varoouis issues that arise with these cars.
I currently have a management light on (yellow) which I clear every day. The code says "mass air flow sensor high" and sometimes another code appears "Mass air flow sensor low"
I have changed the filters on both sides of the unit and taken the whole unit off to spray clean the inside copper looking sensor, one on each side. I thought this had done it as the light didn't come back on but the following day it did. I don't know what else to change to make the light stay off? There are 3 what look like sensors on the unit, one sort of in front of the turbo and the other two on either side of the unit. BUT I don't know where to get this sensor if it is this that's the problem becuase whenever I search for it, all I can find is sensors for Mercs with 2006 engines and the MAF is nothing like the one on my car.
The link below is a similar one to the one on the car. (my car is an E350 bluetec diesel 2016 saloon.)
https://www.ebay.co.uk/itm/14374907...aAtDi9HrIFBmzKfshF7IvG6ELz8c5Wl4aAnd1EALw_wcB
If anyone has experienced this or knows what to do, I would be extremely grateful for some advice. I am definitely NOT a mechanic and the last time I worked on a car, it was to replace the brakes and pads and alternator on my childrens cars. Playing with a nearly new car scares me i'm sad to say!
Thank you in advance.
Adam.
Adam.
