brandwooddixon
- Jul 31, 2006
- Location
- Wolverhampton
- S63 Coupe 2014
Well I've been having some interesting discussions with MB regarding the 722.6 gearbox fitted to the W210.
This was started when my gearbox suffered an major failure (basically destroyed itself).
In the course of this discussion with them I even asked them to comment on why MB document "Circular PW NR. 44/05 NFZ NR. 20/05 24.03.2005" requiring a one off oil change for 722.6 gearboxes as fitted to 203/211/220 doesn't also relate to 722.6 gearboxes fitted to 210 models?
Their stance as summarised by their last reply:
So there you have it, apparantly we're all imagining that our gearboxes need servicing and by their own admission newer gearboxes are more fragile and less reliable.
Oh and a final point even though they didn't directly answer my enquiry about the 722.6 gearbox fitted to W211s I've been black listed on this subject:
I have reviewed your concerns and your comments where you stated that the point of contention is that the service schedules for W210 vehicles have never been amended to take into account what is apparently a common failure mode of the 722.6 gearbox, principally triggered by the lack of oil changes.
As stated previously, I investigated this with our internal advisors who report on technical aspects noted in your correspondence. The manufacturing process, designs or maintenance schedules of our gearboxes have been diligently and assiduously tested. Mercedes-Benz does not have any registered known issues regarding sealed gearboxes similar to that of your vehicle.
As for the change in maintenance policy for later models, this is because the components used are different and in accordance with technological advancements, maintenance requirements change too. Further, as the repair was not carried out within the network, we cannot establish the cause of the failure.
I apologies for any inconvenience that the matter may have caused you. Our response remains the same and we are unable to over turn or add to the comments already provided to you in previous case investigations. Whilst we are happy to assist in any issue you may have, further correspondence on this particular topic will be logged for reference.
