Memory seats
The Pan Man
Warwickshire
2008 E 500 A/G Classic colour combination.
Can anyone answer this? Which way to programme and store the memory function. M + 1,2 or 3? or 1,2 or 3 + M? I know that you have to set it up but I can't seem to get it right.
When the comfort access has been used I can't seem to get the seats back into position unless I use the buttons manually. I must be doing it in the wrong order or not holding the buttons long enough, is what I think, but I'm sure someone will know the answer.
Remenham
Bolivia
a140
M then the number. When you press the number the seat should move to the position stored for that number.
As above, by pressing the memory button it releases the memory, you can set the car up in 3 different ways, by setting the seat to one position, then press 1 for a few seconds, alter the adjustment to give you an alternative driving position and press 2 and so on.
If you have another key, you can set that key up with the 3 settings, fine if someone else drives the car and they have their own key
The Pan Man
The Pan Man
Warwickshire
How about to store the setings? Is it the same M + number?
You just push M to open the memory, then any number stores it automatically
The Pan Man
The Pan Man
Warwickshire
Thanks Malcolm
Thanks Malcolm, I will have a play tomorrow to try and sort it out in the car and my head.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
Worth bearing in mind is that when you want the seat etc to move to position '1', you have to press AND HOLD the '1' button uintil it has finished moving everything into the set positions.
If you press and then let go, stuff will jerk into life and then stop where they are as you release the button.
It is not a one-touch operation.
When setting, you have to press 'M', release it, and then press one of the numbers within 3 seconds of releasing the 'M'.
HTH
P.S. It's also worth RFTM! ;)
The Pan Man
The Pan Man
Warwickshire
I did RTFM but not plain English as most things MB when it comes to instructions. Thanks
