Merc 308 brake replacement
paulfordy
Hi folks, a friend of mine has asked me to replace the front discs and pads on her J plate 308D.Although i work in a vehicle workshop i havent worked on one of these vans before and i would like to know what tools to take with me to remove the caliper and carrier and discs?.
Also what tool will i need to slacken the serpentine belt tensioner as so i can fit a new one?.
I just dont want to travel a long way and not take the correct tools.
Many thanks!
:D
Normal sockets and ring spanners, some calliper (ate) are held with a 7mm alen key.
The belt I cant help on sorry
dava
The Toon
13mm spanner 19mm socket 21mm socket and a screw driver to push the calipers back.
P
paulfordy
Thanks Guys..much appreciated! :D
dava
The Toon
You might need a torx bit to get the disc off the hub, depends if its a pozi or that. Centre pop usually sots them.
