georgehoffman
- Nov 19, 2005
Hi, i have a problem with my manual diesel merc. Runs fine most of the time but all of a sudden the EPC light comes on and the car will only rev to 2000 rpm and surges, it will only run in 1st,2nd & 3rd when this occurs.If the ignition is momentarily switched off it can cure the fault for a few seconds or a few miles. This problem can happen straight from cold or it can go for miles before it occurs. Mercedes say they can put it on their machine and it will give fault readings but then it is a matter of changing various things to see if that solves the problem but this is an expensive process to me. I feel it cannot be the fuel pump but possibly a sensor or relay problem. Any suggestions please. thanks.
