anyweb
- Jul 15, 2005
- Age
- 58
- Location
- Sweden
- Website
- www.niallbrady.com
- c238,w120 (diesel)
hi guys,
my mercedes c220 has decided to annoy me. Tonite I wanted to drive to the shop and get some stuff, but when i inserted my key and turned, i got the impression that the immobiliser (if there is one present, i'm only guessing) had kicked in as the red/green leds on my rear view mirror were flashing alternatively.
I've seen this problem only once before (i've owned this car since april 2005) and back then, i tried on/off with the key FOB 10 times or so and got out of the car, locked it, got back in again and it started. Today however it simply refuses to comply,
when turning the key the car sounds like its choking itself, the power to the dashboard lights dims a lot and once i stop key turning the RED/GREEN leds flash at me very fast.
I have seen the red/green leds do the following,
RED on when i tell it to close the car, GREEN on when i tell it to open the car, RED/GREEN flashing TOGETHER at the same time and RED/GREEN alternating.
I've also noticed that the dashboard Clock is set to 0:00 (not the trip, the clock) which is odd as the sony stereo correctly displayed the time as 21:45....
In an attempt to figure out the problem i must mention that earlier in the evening i attached a trailer 13 pin to 7 pin connector (which i just bought) to see if i could fix an annoying problem i have there (the issue there is when the supplied one is connected, my left/right indicators act up flashing VERY fast, or very slow), anyways the one i bought (new/non merc part) didnt cure that problem, but it was a troubleshooting exercise for me.
I did not attempt to start the car between doing that quick 1 minute test and when i tried this evening so what i'm asking is
* have i caused the problem ?
* how can i fix this problem ?
i need my car tomorrow so i'm really hopeful that some of you can give me a clue where to look and how to fix/troubleshoot
i have check later tonight (23:45) and the instrument panel clock is still saying 0:00 even though the car radio says the correct time... is this telling me something ???
thanks in advance
anyweb
thanks in advance
anyweb
