drivinggod09
can anyone advise me on this i have a 230k clk on x plate had oil leaking from camshaft adj into ecu causing 02 sensors to mess up stopped the oil leaking into ecu and cleaned out but from the ecu to the 02 sensors in exhaust is still oil causing the sensors to mess up again is there anyway to stop the oil so it dosnt get to the sensors but stays in the loom or to clean it out while its on the car merc said needs a new loom as they dont bother cleaning them anymore and 6 hours labour at 100 plus vat was thinking of using silicone on the actual wires before 02 sensors to make a oil tight seal or running the car on ramp with o2 sensors disconnected if poss and dispursing oil with spray untill the loom runs clear any ideas cheers
rob
rob
