Mercedes 190 E cutting out
Status
Not open for further replies.
fletch
Hereford
I said I would post when I had the solution to the cutting out problem that I was having with my 190E. After taking the car to the local independent specialist on several occasions I finally contacted Andy Gayle in Smethwick . I can only say I wish that I had done so earlier. They diagnosed a faulty/damaged air flow meter. After fitting a new air flow meter (not cheap but there we are) they made the necessary adjustment to the fuel injection system and Bobs your mothers brother as they say. I have driven the car approx 1000 mile since the work was completed & there is no sign of recurrence, needless to say I am delighted the car now drives like new, fuel consumption has improved and I am now fully enjoying the Mercedes experience. I would recommend anyone with similar problems to give Andy Gayle a try. I would be happy to provide anyone with contact details if they PM me.
:D
dan 380sel
Essex, Uk
I have the same sort of problem with my 380sel could this be the problem? where about is this person based and could you give me the number so that i can contact him.
dhardy@uku.co.uk
Daniel
C
carolineleprof
190 E Auto Cuttingout Your solution?
Opinion please. Was replacing the airflow meter the whole answer? Or did some other things that you had done contribute to the solution. Also is it really now fixed? My car will run for a week, then cut out. Sometimes more than once on even a short journey.
F
fletch
Hereford
Caroline,
I think that the answer is probably yes, although a second hand one could be sourced given time. My experience was similar to your own. on some occasions it was really bad -often in traffic & then the problem would not reoccur for a while.
C
carolineleprof
Thanks it's just that my car is going back to the garage tomorrow & I don't want to waste more good money, after bad if it's not going to solve the problem. As my car is a 1991 190 E Auto even though it's low mileage it's not worth spending a fortune on. :!:
Status
