MJD
- Jul 24, 2014
- Location
- EXETER, DEVON.
- CLK200 kompressor 2002
Hi all,
I Have a 200CGI e class. Petrol 1.8 manual.
Two oil leaks, one from the turbo feed pipe, just about to order from MB, Two banjo washers and oil seal rubber?, any advice on other suppliers if MB no go would be appreciated.
The second leak appears to be coming from the oil filter (plastic) assembly, This is located at the back right hand side of the engine and is bolted to the engine block, My question is does this have a dedicated gasket or is it a instant gasket seal?, Could anybody help with schematics/diagrams of assembly removal? pretty limited access but should be possible DIY.
Thanks for your help. Mike.
