I have a problem with the ABS warning light not going out on engine startup. It does go out sometimes after engine run awhile. Whilst the ABS warning light is on the tachometer does not work. When light goes out Tacho works OK. When light is on engine runs a little uneven, when off engine runs smoothly. Does anyone know what the likely problem to be and is there a cheap solution? Thanks
Alan B
Alan B
