Mercedes 38 pin to 16 pin OBD II Adapter
http://www.ecufix.com/shop/index.php?main_page=product_info&products_id=191&zenid=b53954c5975c3d3b787851607c5cc6d0
Found this today while browsing.
Is my 1997 E300TD OBDII compatable? Obviously this is just an adapter, a fault code reader/resetter would also be required.
You have chosen a hard year, things all started to change from here onwards.
If you only want to do engine checks, this can be done with a simple diode and a swtch.
If your car is OBD11 compliant there will be a 16pin socket under the dash, but I do not think it started on yours till 99
to check this on an MB and you need to spend £2-3k
Malcolm
robs-mbz
robs-mbz
Newcastle under Lyme
1997 E300TD
What checks can be done using a diode and switch? How are these checks done?
All faults in the engine and a few others can be read out by counting the flashes of the LED tool (easy to make) and cleared by a switch on the same device.
Do a serch on MB 38 pin read out, (I have a tool laying around somewhere.)
The fault codes and how to make the tool are out there.
Malcolm
stats007
Hampshire
Looking
Just to clarify the diode is in the form of an LED - the switch is a bonus you don't actually need it.
OBD2 is vary rarely used with Mercedes in this country - the data can be obtained through the 38-pin diagnostic port as a duplicate on these later cars. The US made it a requirement in '96 I believe - Euro SLs got it in 2001.
www.ckinsurance.co.uk
