my mercedes 609d has developed a clanking banging noise underneath when being driven seems to be coming from front when accelerating when decelerating slight noise at the back can anyone please help me
That's a very vague description of the problem but I will give you a start. If the noise happens when going over bumps then check all the shock absorber bushes front and rear and also any antiroll bushes as these can cause a funny rattleing sound if worn (worn antiroll bushes are obvious as the bar will slop about in the bush visibly.
If it isn't a suspension noise then check the universal joints on the propshaft, there should be no play in them otherwise they can cause a lot of vibration/knocking and will soon fail catastrophicaly if not fixed.
noise dosent happen going over bumps when accelerating it sounds like metal against metal as though being hit with a mash hammer really loud bang, clank
Well it definitely sounds drivetrain related. If you can't pin it down yourself you really should take it for a professional opinion asap. It sounds like it could be serious and might fail without warning if left unchecked.
Without being there to see for myself I would say it could be broken gears in either the gearbox or axle or still worth checking the propshaft. If it is that noisy a propshaft fault should be obvious.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
