Mercedes Benz ML 320 CDI Sport
GARETH12345
ML 320 SPORT A 2007 2967CC
Hi all after driving about 4 plus miles the wipers/indicators don't work the sensors come on and off
cheers
Gareth
Larkone
NW Essex
C219 CLS 320CDI 2008
If you could re-arrange that into English or add a bit more to the explanation then perhaps we can help.
G
GARETH12345
Sorry, I have not got a clue about cars. You Drive for a few miles then lights on the dash starts flashing (DRS, Batterie, ABS,) then the Windscreen wipers, Horn and indicators stop working.
cheers
Gareth
Hello and welcome,
What condition is the battery in? (When was it last changed and what is the voltage at rest (car switched off)
Any leaves blocking the scuttle drains below the windscreen? (If so remove them as they can cause water to leak into any number of places including fuse boxes and the like causing random electrical faults)
G
GARETH12345
Hello and welcome,
Hi when I called the AA the battery was ok. 2 square grey little boxes in the electric compartment in the boot are getting hot after driving a few miles??.
Larkone
NW Essex
Then you need to get this on a STAR machine to get the codes read. If you post your location then someone will recommend a good Indy in your area - much cheaper than the main stealers.
www.ckinsurance.co.uk
