mercedes c250 td 1999 transmission S/W switch query
jfk196
New Registration
i've just bought a c250 td (1999). it didn't have the owners guide. does anyone know what the S/W swith on the auto box refer to? thanks! oh and any ideas where i can get a new key from ? (lasercut fob 3 buttons) thanks again!!:confused:
Jensen
I've got exactly the same model. S switch = Summer W switch = Winter.
Basically in W the car pulls away in second gear ie in snow and gear changes up at lower revs.
I always drive in W as find it a smoother drive, particular in a que it dosn't jerk forward as much.
To change the settings between S & W this can only be done when you have the car in reverse gear. Simply by pressing the switch in Drive or Park will make no difference.
Glenn Smith
Peterborough, UK.
Didn't know that! is it the same for all? i have 5speed tipshift in my c230k
Mine changes in Park, I can feel it change from 1st to 2nd as I press the switch. As for the key a Mercedes dealer is the place to go. The ones on Ebay are of no use.
hexflyer
slough
You can change from W-S in P,N,R;) , used it on W yesterday and yes a much smoother ride no jerking from 2-3.
mine is now overdue an oil/filter change by 3k oops!! so will do a change next week with some cheaper oil, will then do a run to newcastle and back about 600miles and do another oil filter change but fill it with the good stuff mobil1
jberks
Sorry but no.
You may only 'feel' the immediate difference in R (although I've noticed it on other settings) but it's simply a signal to the computer to change the behaviour of the box so can be switched at any time.
W is smoother but only because it allows more torque slip which in turn uses more fuel (though perhaps minimal). I used to keep it in S unless I was in a traffic jam in which case I'd switch to W to both smooth it out and also as it sits in 2nd, crawling along in traffic is faster so I don't need the throttle as much.
edward28
West Sussex
I have a 99 C220 cdi tip auto and can change from W to S whilst in D!!!!!! OH by the way does anyone know how many miles i should get from a tank of diesel???? Edd
~500 miles
racall
london
c class and slk
oil
mine is now overdue an oil/filter change by 3k oops!! so will do a change next week with some cheaper oil, will then do a run to newcastle and back about 600miles and do another oil filter change but fill it with the good stuff mobil1[/QUOTE]
I was told that mobil 1 (altough good oil) was too thin for your C250 and was a waste of money!. I was recommend fuch oil from euro car parts.
hexflyer
slough
I was told that mobil 1 (altough good oil) was too thin for your C250 and was a waste of money!. I was recommend fuch oil from euro car parts.[/QUOTE]
interesting, but you may well be right, it being an older gen engine
Back to the original question of W/S use, though I have only had the V8 for a couple of days. The driving in W is made much more relaxing, in S I can spin the wheels so easily and subconsciously think about it. In W I can drive without thing about it. If I need first, I can kick it down.
For me having two cars that have this huge appitite for rubber it does help, on smaller engines one does not get this problem.
Malcolm
