Mercedes E320 2001 Oil Explosion
Finnley
Mercedes 2004 e320 Mercedes e320 2001 Mercedes e320 2003
Engine full of oil
F
Finnley
  • #2
F
Finnley
F
Finnley
Hello I have my other Mercedes e320 2001 it started to rattle and we got concerned. It had been sitting for a long time as we no longer used it due too the rust. We used it for spares and ran it every month to recharge the battery incase it ran out of charge. As the rattle got worse we took the cover off and saw that engine was full of oil. We are thinking of buying another old e320 like this as we have had loads of problems with our 2004. Before we look do you know any way of knowing or checking if this could happen and know why this happens aswell.
F
Finnley
im pretty sure its coming from the valves but I don't know why oil was regularly changed if think one is split of something not too sure atall
F
Finnley
Where's it coming from ?
F
Finnley
Any ideas?
umblecumbuz
Wales and Gozo
Is it oil, or is it more like thick black treacle?
If it's the latter, it points to a leaking injector.
You'll soon see when you remove the engine top covering.
If you also hear a 'chuffing' noise when the engine is running, then this also suggests a leaking injector seal.
F
Finnley
Yea abit like chuffing or rattling and it got worse this was happening when it was idle and then I took the cover off and saw this
Craiglxviii
Cambs UK
Did this hydraulically lock on any piston?
Naraic
2005 CL500.
When you say "explosion"...did that happen, or just a misleading title?
I'm confused because the top cover looks like it is in bits. Or, do you mean just "black death", which is easily scraped of with a flat blade screw driver and then have the injector/s reseated.
F
Finnley
  • #19
Top covers been taken off to look at the engine
F
Finnley
  • #20
Just noticed that the bit that seems coated in oil is actually the undercover for the plastic engine cover. SO where is your plastic engine cover? That foamy part should be glued to the plastic part.
Plastic engine cover has been taken off
