mercedes e320 cdi 2000 model reving problems
jukebox
hello,
would anyone out there have any idea on the problem i have with my 2000 320 cdi just started with trouble that it wont rev past 3000 so making it sluggish when you need to put your toe down ??
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Any smoke????
failed cats restricting the exhaust, possibly failed MAF.
jib
jukebox
ta jib
no smoke but what is cats and maf (non mechanical) ?
malcolm E53 AMG
The MAS (or MAF) is seated at the entry of the air cleaner. Odds on that this is your problem and is easy to replace. A MAS failure send the car into limp home mode ie won't rev beyond 3000rpm.
Euro car parts will fix you up or a Bosch agent will supply the internals if your prepared to salvage the outer casing of the old unit.
l777pen
New Registration
Revving problem
Hi Jukebox
I had a similar problem. It was the hose on the air intake collapsing when I revved and restricting the air supply. Simple to check get the engine revved with the bonnet up and watch the pipe
