Mercedes e320 developed a water leak but has got worse i also suspect oil leak as well
SIMONGRIFFITHS
New Registration
e320 2004 3.2
car had small water leak which got worse over a week engine still runs fine but never over heats the leak seems to be left side of engine also there seems to be a lot of oil but that could be old any advice please
Car is a E320 3.2 cdi 2004
bembo449
gainsborough , lincolnshire
Dont ignore a water leak , get it up in the air with it running to see you can spot or a garage that can put the system under pressure and check that way , could be a number of things from waterpump to cracked housing
AMGeed
Poole, Dorset
S204 C180K
+1 for water pump which will get worse if its not fixed soon.
With the engine off and cooled down, put your hand under the water pump and feel for a leak.
The oil leak could be investigated at the same time the water leak is being fixed.
